Disabling interior lights when opening sliding door
CraigG
Salisbury
T6.1 Ocean 150
In a California Ocean is there a way of disabling / stopping all the internal lights in the rear of the van coming on when the sliding door is opened?
I think camping mode will do this but I don't want all of the camping mode.
Switches by the rear view mirror
On the 6.1 you can pick what you want on camping mode. tick the box of which lights you want off. unticked is on.
Coincidentally, this morning I noticed the light around the bottom of the sink lip/cupboard was permanently on (whoops). I went into the camping screen > lights > and turned it off :)
It does, but you have to go back in every time you start the ignition to reset it.
I'd use @WelshGas suggestion
I tried using the switches but they failed to switch off the lighting around the sink unit/cupboard... Went to the camping screen - worked first time... It appeared to be a permanent solution - will keep an eye on it :)
No lights at all when I open the cab doors or sliding door on my T6. Super stealth mode… but does leave me fumbling around for the switches when it’s really dark!
