Door lock button not opening doors??
Chico
Chico
Pembrokeshire
T5 SE 140
Door lock won’t open doors? Door lock locks doors. Keys open and close doors. I presume it’s the door switch is faulty??
Drivers door central locking switch. it locks doors but doesn’t open them
Agree, it could be the switch.
But it could also be a broken wire in the wiring loom from the A pillar to the door, near the upper door hinge. Not uncommon in older vehicles.
You could remove the switch and trigger the door locks by bypassing the switch.
If that doesn’t work then you’ll have to trace the wire back.
New switch, to check / discount other issues is the cheapest option and should be the first check .
Californication69
Californication69
Californication69
Trollhunter
Trollhunter
Trollhunter
