Barryjm
- Messages
- 231
- Location
- Forest of Dean
Hi All,
I am busy making a shorter parcel shelf for my Cali, which will give a more flexible living space and a shorter bed, which I hope will not be a problem as I am 5'9'' ish and the standard bed must be around 6' 6'' in length.
I am after advice on drilling a 14mm hole (or two) in the cabinet :crazy as I want to move the parcel shelf bracket on the cabinet side back a bit. I have purchased a brand new 14mm metal bit for my drill but I am nervous as drilling a hole of this size in metal is not always a simple matter. I plan to put a pilot hole through first to keep the larger bit in the right place. Any one have any advice??? :idea:
The bracket on the drivers side appears to be fixed to the body work, so I was going to leave this well alone!
Also I need to make a shorter foam matress to match the parcel sheld length, can anyone recommend a site to purchase a new piece of foam and covering material to match the Cali original cover?
Best Regards Barry
Best Regards Barry
