Calimili
Two das ago I've picked up my 2019 DSG Cali (57,000km on the clock) from the VW dealer after a Service, the 60K Km/40K miles one which include an Oil change of the DSG. As I drove it off the VW dealer lot i noticed the oil temp at 78°C, so it was already warm. Same for water temp.
As I drove home i started noticing some issues, like it being hesitant which gear to hold 2nd or 3rd on slight inclines. Then suddenly the gear went in (or the clutch released suddenly?) with a bang. This happened also sometimes from 1st to 2gear. Or it accelerates in 2nd gear, then suddenly no more power, then power on again, clutch engaging and releasing. Always on inclines going up.
After reading everywhere online I thought/hoped the DSG needs to "re-learn" my driving habits ? Calm relaxed driving by the way.
Following day, yesterday, I decided to test it again and it seemed all banging was gone , shifted normally, with still some minor hesitation in gear 1-2 shifts, but no sudden clutch releases. Notice that i tested it from cold, for about 20 miles.
Today long test again, it seemed all ok, convinced the DSG has "relearned" my habits. One more loop around the village and twice hesitant in 2-3 gear shift again, and once with a bang. Then a wrench symbol start flashing on the dash where the gear indicator is, upper right corner. Then it got stuck in 1st gear.
Coincidentally the dealer called me in reply to my Email at this very moment, and tells me to turn the engine off and on again, the wrench should go away. It did, but the DSG issues still there. So I'm scheduled to bring it in on Monday, the gent at the phone mentioning maybe incorrect oil amount (not enough) or need reprogramming software.
Before the DSG oil change no issue whatsoever, never, always smooth.
The Email I've sent today, was a "cover my ass" as on Sunday, in two days, my 5 yr warranty expires. Although I am 1000% convinced the DSG had no issue before and the problem came up because of the dsg oil change.
Any of you guys experienced anything similar after a DSG oil change ? Any advice would be greatly appreciated. Thank you
