Eberspacher default setting
2into1
2into1
Née T4WFA. Now without Cali :(
Glossop
Just browsing
Just wondering if there is an easy way to change the default setting of my eberspacher cab heater on my 06 Cali. Using the remote, the overhead button, or the menu, all bring it on at no 7, when for keeping the chill off, I find no 3 fine, so I'm always having to adjust it.
Any quick remedies I can apply through some hidden settings?
Our 2012 Beach always defaults to the last temp that you had it set at.
If you switch the Control Panel Off, there is no real need to do this every time, then when switched On the Parking Heater will be set at Maximum, 7.
However if it is not Switched Off and left On then the last heating level will be the default for the remote or heater button on the Control Panel.
I'll try that, thanks WG. I sometimes do turn the panel off, but not always so perhaps that is the cause. Cheers.
