MartG
I don't have a diagram and mines an Ocean, but you are correct with point 2.
The Oceans charger is next to the fridge, so I'd guess that the Beach is near your toolbox, left rear side? or near the battery under seat?
If they disconnect the RCDs van side, then try resetting it on power, this should discount the RCD, which often go faulty. Some are more sensitive to out of balance currents and will require a connected load to test.
It 'should' be easy enough to access each screwed connection (checking for tightness as @Paul Morris correctly mentioned above) on all points without removing any panels other than the removable hatches (not sure about a Beach tho).
