E
Elizabeth Silman
- Messages
- 84
Just bought this from the Club shop but it has no instructions - does anyone have an idea how to use it?
Never fitted it, but think the small part slides onto the awning track and the bigger one slips into the roof rack slot at the front. Use the Velcro strap looped between the two to hold down the roof if the mechanism fails.
You should have two of these sets, one for each side.
Alan
It only needs to fit right at the front so that the wind does not get under the roof and lift it off when the scissor mechanism is not locked downWas thinking the same , but what on the side where a wind out awnng is fit...
The rail is not acceseble , or just the front part.
Need to check ....
The shape of the larger plastic part is designed to fit into the shaped slot at the front of the roof rail.
Alan
Front part of the rail.
Pray to whoever you believe in it is going to be the most redundant item in the Cali "essential" bag. If I ever had to use it then I would just blankly give it, still in it's wrapping, to the VW assist man, having no idea how to use it or how to get the roof down if was in the "Up" position in the first place
I've just ordered the tie-down kit from the club shop, but it only came as a kit for one side - should I have recieved two, or should I have ORDERED two, which seems a bit daft as there was nothing in the description to say that.Never fitted it, but think the small part slides onto the awning track and the bigger one slips into the roof rack slot at the front. Use the Velcro strap looped between the two to hold down the roof if the mechanism fails.
Alan
and a second spare wheel/tyre?Think I might order another to be sure, to be sure...........
Having experienced roof failure and having had to drive from one side of Scotland to the other in a reasonable time to get it repaired, there is no way I would risk driving with only one velcro lash down. The consequences of wind getting underneath the unsecured side and lifting up don't bear thinking of!
I'm pretty sure all vehicles should be supplied with two, our T5 and T6 were. Check the make sure you always carry them, you don't know how far you may have to drive with them securing your roof.
I agree if you don't wish to restrict your driving speed then 2 might be advisable. However I don't think I would put all my faith in 2 plastic inserts and some Velcro.Having experienced roof failure and having had to drive from one side of Scotland to the other in a reasonable time to get it repaired, there is no way I would risk driving with only one velcro lash down. The consequences of wind getting underneath the unsecured side and lifting up don't bear thinking of!
Very much my thinking - also, on the 'take an umbrella' principle, that if I have two I'm never likely to need them!Having experienced roof failure and having had to drive from one side of Scotland to the other in a reasonable time to get it repaired, there is no way I would risk driving with only one velcro lash down. The consequences of wind getting underneath the unsecured side and lifting up don't bear thinking of!
£26 for 2 is a bit steep if you don't have them.
Not to the vehicle but to a bought Tie Down strap to go across the roof from side to side it is. If you wish to keep it OEM then that's not a problem.Not when compared with the cost of the vehicle.........
