sidepod
- Messages
- 6,320
- Vehicle
- T4 PopTop
Ok, some did some didn’t leave the factory with engine battery charging.
If you use the van regularly all year round then it’s probably not an issue.
If, like my bus, it spends the bulk of the winter hibernating then it could be an issue.
My last van had it so for me, it’s a thing. My current van doesn’t. Here’s how.
Strap in .
Here’s what you need.
Charger.
2 pole switch rated for 240v
Inline fuses (1A) x 2
Voltmeter (optional)
Switch for voltmeter. (optional)
Note - the double pole switch and fuses in both L and N are to keep the European reverse polarity doom-mongers happy.
Here’s the schematic. For the 240v input to the charger I T’eed into the mains socket outlet. It’s simple to open up and there are screw terminals there to connect to. From here it’s to the charger via two 1A fuses and a double pole switch.
So start by removing the B pillar panel behind the drivers seat (passenger seat if T5 rhd)
Watch for the clip down at the bottom near the footwell.
Various connectors behind the panel to remove.
240v skt
12v skt
Mini fuse board. Don’t worry here they can only go back one way.
So next, decide where you want to mount the double pole switch and voltmeter.
I opted to put in a voltmeter so I could see the engine battery is charging. There are LEDs on the CTEK unit but it’ll be hidden out of sight.
I added a switch to the voltmeter feed so it can be turned off to avoid draining the engine battery when it’s not on charge. You see, always thinking
Ok, now to the compartment below the fridge. This is based on a 4 but the principle and architecture are pretty much identical for a 5..
To remove the fridge panel you’ll need t access these 3 screws in the left hand cupboard.
Once inside, draw the cabling for the charger/voltmeter through behind the cupboard unit.
I used a steel draw wire. Fast and simple.
So, this is where the CTEK unit mounts, right next to the split charge relay. This basically isolates the leisure batteries and engine battery when you cut the engine. The good news is that this provides a direct link to the engine battery.
......out of space.....see next post.
Strap in .
Charger.
240v skt
12v skt
