Error: stop-start
Thanks for the tip. I can’t see anything obvious - I’ll put it up on the chocks next time I start it up, so I can see better
Is the airbag fault only on scanning or is it on the dash? Some of these things can occur if the battery has been disconnected or changed, the airbag fault being one of them.
Doesn’t explain the abs fault code though.
I had a good search through the forum (s) and it isn’t a fault I have seen reported. Given a fast idle condition non regen state I speculated it might narrow the options down. I’ll post any relevant bits of the scan. Might help someone else.
Did you delete the error codes?
If there is a genuine fault then they will come back.
Recently did that with mine. I had 4.
I didn’t make a note of them but recognise a couple of those.
I looked them up at the time as you can do in Carista. By clicking on the fault number it takes you to a website with a description.
One was to do with adblue and another to do with tyre pressures.
I’d had the adblue done and a recent puncture.
Reset and they didn’t come back.
Mike
Thanks for the comments, folks.
I reset the start-stop error one and it came back.
I have no airbag error on the dash (but have recently disconnected the battery)
