Fast clicking noise - behind passenger head lining?
K
Kieran
Bristol
T5 SE 180
Hi, Any idea what could be causing this clicking noise behind the head lining on the passenger (near side)?
It’s not the dash cam.
Thanks for your help.
Have you tried operating the roof to see if it makes a difference? Could be something amiss with the pump.
Thanks! That looks like the problem. I have a 'Roof Open!' message on the control unit (roof is down) and now the unit will not shut down unless I go into the unit settings and change the unit to the no roof variant.
Mice having a rave party?
Seriously sounds like a bad relay possibly the roof lifting mechanism/pump.
It's a mice free zone!
I think I've solved the problem. I located the 30amp roof fuse and discovered it had a bit of corrosion. Scraped it down, re-inserted, and all back to normal! :thumb
Thanks for all the advice guys.
