JAG7001
yeh, its rebooked in again for next month.It all depends on where the leakage is coming from.
If it is from the connection from the water tank up to the lever, the whole cabinet will have to come out because all those connections are behind the cabinet, inside the van.
On the outer side, you will only see a hole where the water comes out.
wardrobe needs removed so they can access it all, dissappointed, but not much i can do about it i suppose.
