Fitz@CFB
We have a 2018 Ocean. Both the 12v socket behind the kitchen sink and the one at the front of the pop-top roof have stopped working/charging. First thought - must be a fuse. Found an excellent annotated photo of the fuse board under the seat (I think posted by Loz for which many thanks)
Attached photo shows our version which is slightly different - it has an extra 4th 15 amp plus 2x 20amp ones next to it in the top row.
I have managed to confirm that the first 15 is indeed the 12v socket by the bench seat at the C pillar as per Loz’s diagram, and that all 4 15 amp fuses are good.
I can’t find out what the other 3 15 amps are for nor the 2 x 20 amp ones. Certainly none of those fuses solve the mystery of the u/s 12 v sockets behind the sink and in the roof.
Can anyone confirm what these fuses are for please? Also if a blown fuse is not causing the problem with the sockets what should i look for next to fault find.
Of course it is under warranty and I could just default to the dealer but its a 2 hour round trip and I want to get more familiar with the detailed systems in the van to be able to fix stuff while its in use.
Many Thanks
Fitz
Many Thanks
Fitz
