Bramco
- Messages
- 793
- Vehicle
- T5 Beach
There I was looking to pull a fuse to disable the OEM DRLs because I have had the led DRLs fitted and lo and behold VW don't even give you a diagram showing which fus is which!
I can't believe this - imagine you are in torrential rain and your windscreen wipers fail. You can't even check if it's the fuse. Is this a conspiracy between the breakdown service insurers and the manufacturers?
Also, I've paid good money for a complex product - I would expect it to be properly documented.
Anyway minor rant over - does anyone know where the fuses are documented on the interweb. I can't seem to find a definitive version. If there is one I'll print it out and make my own supple!ent to the manual.
Thanks in advance as usual if anyone can help.
