ArunAlec
My Cadac Safari Chef 2 has the quick release but doesn’t stop the legs folding. I think they fit it as standard on the “QR” version.I say up front that we have a Transporter conversion, so not a bonafide Cali.
Cath uses the internal burners only for 'small stuff' like boiling a kettle for some rice or a cuppa, and a Cadac Safari Chef for everything else. Hence we spec'ed an external gas point under a flap (similar to the EHU) and we carry a gas hose with quick-release connectors for the Cadac. Hose is in 2 sections, a 3m and a 7m so Cadac can be up to 10m from the van. Pressure is fine over those distances and all fed from the normal 907 bottle in the van. No need for additonal regulators.
I've no idea if Cali's are available with external gas points or if such could be retrofitted (if not, I apologies for wasting your time) but the setup is very convenient.
PS: The quick-release connector saves all that fumbling at the Cadac end, but it protrudes a few millimeters. To allow Cadac's legs to fold in for storage, I drilled a 10mm hole into legs 1 and 2.
(Actually, I think I read that trick in another post in this forum - Chapeau and thank you to the author)
