westfalia
The german tüv (mot) is due every 2 yrs, in order to pass the test the gas system
has to be checked also.
I took the van for the gas check today and got my new shiny sticker.
In a nutshell, here's what happened.
With the system closed on the hob end he removed the regulator and pressured the
system up and then waited about 20mins to see if the pressure dropped.
The yellow book says 150 but he says that he always does 300 mbar.
after that he tested the gas burners, after lighting both of them he blew them out
and you could hear them shutting down a couple of seconds later, he explained that if
a window was open and the burner blows out then the gas has to cut off.
I also got a new gas bottle tap as mine was 13yrs old and needed tightening with grips
to get a good seal.
The cost was-
Gas check- 41.65€
Sticker- 2.61€
Bottle tap- 20.23€ all with VAT.
to get a good seal.
The cost was-
Gas check- 41.65€
Sticker- 2.61€
