Following up on this, when I was young and green, I ran out of gas in Austria. I still have the gas bottle I had to buy and the receipt! However, the experience did convince me that refillable was the way to go.one guy used all his gas so he had to buy a new bottle in europe and connection hose.
Thanks Paddy
Have only got our 680 last week and have left it in storage at the moment given all the restrictions so have just snuck down to it once last week for a quick play. So no problems so far!!!
We will go back down again in a couple of weeks once things settle a little bit. So fr though we love it - great spec, love the look of it inside and out and cant wait to get going this summer
Hi MM,Hi
Am looking for guidance as to what I need to buy. Our new GC680 comes with the Irish/UK gas hose pigtails but we are planning to spend our time touring europe. Can anyone advise on where to buy either new Euro gas hose or convertors? Our existing connector hose ...
ThanksView attachment 72090
Hi MM,Given we are planning to leave our campervan in europe each winter we wont be coming home to change our gas cylinders the refillable option looks the best
Thanks for the responses
WillHi MM,
I may have mentioned it before and as Vagophile say if your planning europe you will be much better of with the refillable LPG gas which is readable available and cheap in comparison to exchanging gas bottles.
I opted for Gaslow. You are able to carry x2 11kg bottles, I opted for a 6 and 11kg due to weight. You mainly have all the components should cost you approximately £650 for purchasing the bottles and installation. Filling the cylinders will cost £00.65 per litre.
Check out Gaslow. https://www.gaslowdirect.com/
Will
Hi MM,Will
Thanks for that, do I remember reading that you mounted the fill valve inside your GC rather than cutting holes in the outside?
It’s under the back outside along side the tow bar bracket.Will
Thanks for that. I was trying to avoid putting a hole in the van but after some more reading I think we could potentially run in to trouble trying to fill up in stations if they refused to use an internal connection !
Most gas fill stations will not let you fill unless you have an external fill connection. They are suspicious of people trying to use a filler direct to a normal gas bottle.(where you would have to access the gas bottles in the cylinder storage area).Will
Thanks for that. I will try them when we can travel that far again!!+ Moonlight Motel, in case you haven't sussed them, Hamilton Gas Products (gasproducts.co.uk) based in Bangor are pretty good for refillable gas products, and less expensive than any other supplier that I have found.
