G
gatvol
- Messages
- 519
Just picked up the van. Have my full camping gaz bottle. I bought a little brass tap that has a rubber seal on the bottom that seals against the camping gaz bottle. That works fine.
But where the california's regulator seals against this new tap there is a leak. I tested with soapy water and was a little downhearted to see a leak. The appliance is meant to be hand tightened, so I gave it a minor tweak with a wrench. Still leaks
Am I perhaps missing a seal here as there is no rubber seal between the regulator and the brass tap ? Alternatively that means either the regulator supplied with the california is defective or the brass tap I bought from the camp shop is defective
Any help very gratefully received
