Morning all we have a gas problem to the hob. We have a new camping gaz bottle but have low gas pressure please could anyone give some advice as a man needs a cup of tea in the morning
If the low pressure is on both burners check the gas tap under the cooker is fully open and the gas bottle tap is fully open. If still an issue you may need a new gas regulator.
Probably need a new regulator, I swapped mine recently after problems with low or even no pressure and it all works good as new. Available from the forum shop.
