We have written about it before (see e.g
this thread): indeed butane (Campingaz) stops vaporising around 4 degrees Celsius. That's why they don't sell Campingaz in Scandinavia.
We do a lot of winter camping, and we have got ourselves one of those ALUmini refillable propane bottles, they fit the gas compartment in the Cali, and you do not need to change anything to the setup, regulator, etc. You just need a different valve (seeing that propane has a higher pressure at comparable temperatures than butane; around 30 degrees Celsius the pressure is much higher than what the Campingaz bottle and valve are designed for! Never put propane in a butane bottle!):
We also have a set of filling adapters, because the filling stations in different countries such as Italy, Germany or Norway use different attachments.
You can order these ALUmini refillable bottles, together with a valve and adapter set, online in Germany on eBay or at several on line shops, e.g. here:
http://www.gas-shop-24.de/gasflasche/alugasflasche2kg.php
Careful: there is also a 2.7 kg variant of the ALUmini, but that is too big for the Cali's gas compartment!
The bottle is € 109, a filling about € 6, so if you refill 4 times instead of changing your Campingaz 907 at on average € 30 a time, you have recovered your investment
![Icon Thumbup :thumb :thumb](/data/customsmile/old/icon_thumbup.gif)
