W
Wisp
Looking to use stacking boxes to store contents of fridge. Does anybody have the internal dimensions of the fridge?
FYI : On youtube I saw that there are 3 shelves in the fridge : Above the 'top' basket there is an additional (thin) shelf.Morning.
Base internal length 50cm
Height base to bottom of top basket 22cm
Width front section 24 cm then takes a step in at back to 20cm
Remember the front section of the fridge is for tall bottles or milk as it's clear of the top basket shelf When it slides in.
Hope that helps.
Hello Bobcat01Morning.
Hope that helps.
Thank you Steef. We will check youtube.FYI : On youtube I saw that there are 3 shelves in the fridge : Above the 'top' basket there is an additional (thin) shelf.
There is only 1 sliding basket tray and 1 pull out drip try directly under the freezer.Thank you Steef. We will check youtube.
