Assuming you have a T6.1 (with DSG gear box) if your avatar details are correct.Hi
To move off on a slight hill I have to over Rev the engine that suddenly spreads up the the van leaps of the start
Is this a clutch problem or an engine problem
The Cali comes with an automatic hill-hold feature. So you do need to tell the ECU that you intend to drive, this does require that you press the accelerator a tad more.Assuming you have a T6.1 (with DSG gear box) if your avatar details are correct.
It sounds like a gear box software issue, unfortunately it’s a trip to the dealer for any fault with a DSG !
Assuming you are within warranty also ?
Putting the selector to drive (D) releasing the hand break, without applying any throttle the van should creep forward, if it does not do this there is a fault that needs to be fixed.
please report back to assist others
