Agnes
Hi. Finally took the plunge after ruminating on a purchase for several years. An almost new (2019) Cali Ocean 2ltr deisel DSG Tiptronic 199ps 4 Motion with Solar panels. Done a couple of short trips so far, which were enjoyable, once I got the knack of getting the downstairs bench seat to convert! I find it a bit stiff to move, having wrists somewhat weakened from arthritis. So, any tips on getting a smoother glide would be welcome. Second question, which is probably a bit crazy to you guys, but I am unclear about what runs off what battery. If I use the chargers in the dash, if I have the lights on, if I run the fridge, if I use the 3 pin point on the side of the kitchen unit ( I read that this only works on hook up, but dont understand why). Does all this run down the main battery and then it switches to the leisure one? Which battery will the solar panels be charging? How do I check the voltage on the two batteries? If I am on a hook up does that provide power to all the van's electricity needs or just some? Yikes, so much I dont understand! Happy to read more somewhere if anyhow can point me to an idiots guide to electrics and batteries......
