deltheblue
No it's just a flashing clock stillOk. Does anything happen if you Press and Hold the R lower button and then Press the Control Button for 5 seconds. Do you get to the hidden VW menu?
Small first then middle one then large that's how I did itI think when you plug the control panel back in it needs to be in the correct sequence or else it will screw up the control panel?
I'm sorry but I've run out of ideas. I think maybe the Control Panel may have failed and might have to be replaced.No it's just a flashing clock still
How much am I looking at?going away next Saturday or supposed to beI'm sorry but I've run out of ideas. I think maybe the Control Panel may have failed and might have to be replaced.
You will have to strap the roof down, either with the Official California roof straps, or a rope or strap across the front of the Elevating Section tied to the Grab Handles . This is to stop the roof being blown/sucked open when driving. Speed should be kept down and windows closed when travelling. Unfortunately this is an expensive part from VW, although there is a firm in the Netherlands that some members have used to get their units repaired. Verotronics.
£800 or thereabouts from VW.How much am I looking at?going away next Saturday or supposed to be
It was still controlling auxiliary heating and fridge before I unplugged it£800 or thereabouts from VW.
https://www.ebay.de/p/Volkswagen-7E7906453C/1650721061?iid=372030345092How much am I looking at?going away next Saturday or supposed to be
Only VW will be able to check it out. I don't know if it shows up on the VW Diagnostic Computer, but unless it is something simple like re-coding via the VW Diagnostic software they will just offer a replacement. They don't repair I'm afraid.It was still controlling auxiliary heating and fridge before I unplugged it
I appreciate the help mate I really do
It's a california Jen 2004 2.5td ocean I guess left hookerI presume that a control panel to lower the roof is not a high top despite what the avatar says![]()
I will do stressed out with it now starting to regret buying itWell it probably will not show locked as you lowered manually. The roof needs to be strapped down, why they issue the emergency strap-down kit that you should have. Your best hope is getting it to a dealer who can sort out the hydraulics to lower it and the electronics to lock it. If it is lowered flush to the surrounding panels try anything to place a band around it, gutter to gutter (or is that awning rail to awning rail), then limp along to your nearest vw tech shop.
Had a few issues with it I'll just pay to fix it I supposeWhat a shame. So sorry hon you are going through this. Sorry I can't give you an answer.
