Help please. Used manual override...
Cally57
Devon
T5 SE 130
Hello,
Can anyone help? I’ve just had to use the manual override to get the roof down. Looks like one or more of the sensors have failed. Will have to get that repaired when I get home. The issue is, I’ve wound off the manual release screw but it won’t tighten back up again. Any ideas?
I've never done it. BUT my knowledge of hydraulic bleed screws thinks you have wound it too far .there will be a needle and an o ring in there. To reseat the o ring and restart the thread you will need to apply a little inward force with the screwdriver at the same time as turning the screw.
Thanks. Have just tried that but with no success.
Can' help but i'm intrigued.
I thought a quarter of a turn and the roof starts lowering,
half a turn and it goes a bit faster to lower.
