sidepod
- Messages
- 6,957
- Vehicle
- T4 PopTop
One thing to bear in mind is that these things often sat around for a while before selling. My van was listed as a 2000 model, which was when it was first registered on the road. As it was, it was quite clearly built in 98 as a Joker. This could quite easily be an early model van that has sat around until 98 until being first registered.
Sidepod has cleared up the mystery for me about the rear window, I hadn't realised it was a metal panel on earlier models. So you can discard my earlier musings on that.
As for the parking heater, the intake is on the side of the van immediately behind the drivers seat. The outflow is the two black vents you see on the floor between the cab and living area. These black vents also have a supplementary blower under the van that provides hot air from the vans main heating system when thats running.
Not quite on the vents.
The black vent on the right is fed from a heat exchanger under the van. This takes engine cooling water and produces warm air for the rear of the cabin. Not useable when the engine is stopped.
The black vent on the left (missing) is the hot air feed from the parking heater.
The air intake for the parking heater is in the B pillar below the fuse panel.
