D
dibman
Hi folks, long time lurker and have finally purchased our first California - a 2019 beach! We took it away last weekend and are going away again tomorrow but there seems to be an issue with the leisure battery charging from hookup. Here’s what I’ve ascertained so far…
The battery supplies power ok (lights and sockets work).
Hookup works in that I get supply from the 3 pin socket behind the passenger seat.
The battery charges ok from the alternator (tested using a cigarette lighter voltage monitor whilst driving earlier today - leisure battery voltage went up).
The issue is that the battery doesn’t seem to be charging on hookup. I have left it plugged in at home for 6 hours and the voltage on the monitor has not gone up. It’s been at 12.3v the whole time. Also checked on the engine battery and this shows 13.2v (just checked to see if the voltage meter was working!).
I had a quick look at the battery connections under the passenger seat. Don’t really know what I’m looking at but none of the connectors seem loose.
Should I expect to see an increase in battery voltage within 6 hours of being plugged into hookup?
Thanks in advance. This forum has already been a valuable resource - just couldn’t find a specific answer to this issue.
