T
toeknee
Hi, I have searched forum and watched some vids online but can’t be quite certain that I am understanding operation of the heater, assuming a full tank and almost full battery charge (and with operation mode set to aux heater).
1. When I switch it on, the heater indicator on the control panel lights up and it sounds like the heater is starting up; then It stops; and then it starts again. The second time it starts up the fan really kicks in. Is it normal to do this? Kind of sounds like it needs two attempts to get going. This happens every time on any setting.
2. On settings lower than about 6 it either doesn’t start up the second time or turns off after a few minutes. The heater light indicator is still on but the fan reduces to an almost imperceptible hum and virtually no air coming out of vent. This is with outside temp of about 14C. Even on the highest setting of 10 It was turning off after 20 mins. At this point the van would be quite warm but not uncomfortably hot. Is this the expected operation? It feels to me like the thermostat (wherever that is) has a very low threshold for the point that it puts the heater into a kind of idle mode? At this point the heater icon would still be on.
3. What on Earth is the difference between heat continuously and heat immediately?
4. What is the point of the circulate/ventilate option in the settings menu?
thanks in advance for any advice.
