How to keep your pipe in
I just wedge a cloth or piece of kitchen roll in it
I have a cable tie fixed around the end of the hose cut so that the “tail” holds the hose in place.
for a minute I thought I was on the wrong forum !
(again :rolleyes: )
Its a plastic tank that is connected to the fill up
hole with a short piece of hose with 2 jubilee clips
I always fill up with the pipe good and proper in the tank
i.e. - no nozzle.
:D
The title of this post was meant to be a bit of tong in cheek…... Oops, done it again!!
Simple method to hold the water filling pipe in the filler neck of your van. Stops it falling out even when using high pressure:
My pipe keeps falling out! I’ve got a length of blue food grade hose which I try to avoid contact with the van and the ground while filling but the tap is diagonally opposite the van so it’s a right palava and inevitably get soaked in the process. Where do you get those from?
Where did you find that blue funnel?
Regards from Amsterdam,
Marc.
