TripleBee
Maybe time for a new thread in the how to section without video.
Are you also tired of having water in your van, behind the kitchen? Does it come from the sliding window? In my van, I couldn't stand it anymore and decided to bite the bullet and bought a new sliding window. It changed a few times over the years, so it should be the best window up to now. And with the T6.1 with the new type of sliding windows, it will probably the last update of the old type of sliding window.
It all started with too much water coming in through the slding window, and clogged drains. The front drain is easy accessible, but for reaching the rear drain, the sliding window has to be lift out of the bottom slider. After a few squirts of water and some compressed air, I managed to clear the drains. This helped a lot, but there was still too much water coming in due to the old seal that didn't press enough against the window, leaving a gap between the seal and the window, making the water come in too easy:
Time for ordering a new sliding window:
It comes with metal front pins, instead of plastic. The plastic ones can wear our, making too much play, making water ingress much easier. The plastic pins on the old window were still in good shape, so it all comes down to a worn seal (you can't order separately).
Old window (with the plastic pins and worn seal):
First you have to open the sliding window less than half, and not in one of the fixed positions, otherwise the locking pins at the back will obstruct the disassambly of the window. Then you have to pry out the front bottom pin by lifting the window up at the front (don't use a screwdriver, but some hard nylon pryer). Then you will have to pry out the rear hinge at the back, and that is a whole different story. I used some screwdrivers, and the result is not that nice. The back hinges (top and bottom) pivot and have 2 pins. The other pin is the locking pin.
Then I cleared the drains again, but they were still clear.
Front drain hole, accessible when opening the sliding window:
Rear drain hole, only accessible by taking out the window, or at least prying the bottom of the window out of the slider. And here you can see where the two pins from the pivoting hinge takes a turn, pressing the sliding window to the fixed window part.
Only do this in dry weather!
