Twunt
I was going to order a solar panel from you for my 6.1 beach camper, is it quite a tricky install then on the beach?Indeed - you have already run the cable to under the passenger seat, so in teh base of the fuse holder that I provided, pull the blue connector that leads to the ring terminal, and replace it with the new one I supplied on a longer cable. That way you are still fused, and you now have a longer cable to run to under the bonnet.
I've just installed a kit on a Beach and the relay is fiddly - it's not something I'd make a cable to tap into - it would cause far too many problems. If it were me personally, I'd cut and splice into the big red live - but that's not something most people can do safely at home.
I also checked the big brown fuse and it goes to the leisure battery, not the starter, which is a shame as I coudl have used a piggyback fuse holder to tap into it.
Ok superb, was the victron I was going to orderNot at all. The issues above are related to the Epever Duo charger connection to the starter battery in a Beach, which I've not dealt with before. Most people order the Victron 75/15 for the beach, which simply connects to the leisure battery with two ring terminals.
Plenty of people on here have posted threads on their Beach installations.
R
Sorry to have picked this up, it's just that I have a low voltage electrical background and have been a VW owner for over fifty years so think Brown -ve chassis earth automatically even to the extent that I have to be very careful when working with 240v mains cable not to get it wrong!We switched from thinwall to regular thick wall with the starter battery live as it takes a route that can get crushed in a limited set of circumstances, so wanted the extra insulation thickness.
At the same time I wanted to use a different colour to differentiate the cable from the others in the kit that use red as positive so the installation procedure is not confusing, having to back-trace wires.
British automotive cabling has brown as positive. British domestic cabling has brown as live. So I feel brown is a reasonable choice. The cable has a fuse on the end that is 45 cm from the connector so it is obvious to all that it is positive.
I'm afraid your dismay may turn to aghasteness(?) when I tell you that brown is out of stock everywhere so the next lot of kits will have a blue wire.
