Hi, I have a 2008 Cali since new with 28k on the clock. I have noticed that when I go to start it sometimes the key turns, all lights come on and go out as normal but when you turn the key nothing happens. This occurs more frequently when warm and it can take 3-4 turns before kicking into life. Other times it starts as normal. Battery seems fine. Can any one help? Ignition switch? Starter motor? Fuse? Something else? Thanks Ross
100% cure for intermittent starting issue on my VW T5 found!
Hi, had been struggling with the same issues with my van for 3 years now.
I changed everything from starter to fuses, switches and relays, everything other than the wiring loom.
Been to various specialist vw garages and no one could solve the issue.
Very recently someone recommended a garage to me with out of this world diagnostic equipment.
I phoned them and they said they’d charge £100 to do a diagnostic and if they couldn’t find what was wrong I wouldn’t have to pay anything.
Booked my van in, turned up, handed van over, half an hour later they came out and said they’d narrowed it down to a part of the wiring loom but did not know specifically which bit but for an extra £200 would find out and fix it to which I obviously said yes.
2 hours later my van is fixed and starts perfectly every time.
The issue found was a corroded wire in the wiring loom above the gearbox.
So if you’re having the intermittent starting issues I had, do yourself a favour and post these guys a visit.
If I’d seen them 3 years ago I’d have saved hundreds and hundreds in parts and labour and tens of hours trying to fix there issue myself too, not to mention all the times I missed appointments etc due to my van not starting.
Oak Tree Garage,
Darlington Road,
Northallerton,
DL6 2PA
01609 779213
https://g.co/kgs/RogrjGs
