Kickdown
Barrington Caldbar
Derbyshire
Looking to buy
Had my Ocean since Saturday and noticed that when driving down steep hills the engine drops gear to D3 and even D2 causing overrevving. I wouldn't choose such a low gear in my manual vehicle. Do I have any control over this?
United Kingdom
T5 SE 180 4Motion
Have you tried the DSG manual function?
Barrington Caldbar
Derbyshire
Looking to buy
Good to know it's not a fault. Perhaps if I set the gear as M3 it will be a little better.
RockinNRollin
RockinNRollin
Manchester, UK
T6.1 Ocean 150
Just let the DSG box do it's thing. It's better and less wearing to use the available revs (and power) than labour the engine at low revs.
edocali
edocali
Kingston, UK
I actually find annoying that on steep downhills the DSG changes gears UP for me - I'd want more engine braking ... as I'm used to do with manual vehicles.
RockinNRollin
RockinNRollin
Manchester, UK
T6.1 Ocean 150
If you drag the brakes slightly for more than a few seconds it will start to change down to increase engine braking. What I do find irritating is the tendency for it to slip into "coasting" mode on downhills, but a quick slide of the lever to manual mode then back across forces it back into gear. On very steep roads, I often use manual mode to keep the van in the gear I want (e.g. very steep and tight hairpins I keep it locked in 1st as the box tries to climb into 2nd too quickly)
CaliforniaPhil
CaliforniaPhil
Midlands
T6.1 Ocean 204 4 motion
Sounds the same as my 72 plate. In auto mode down hill, the box goes down the gears to try and stop the van going too fast. Often seems to be revving hard. Only way is DSG into manual and help with a bit of braking.
If you haven't discovered coasting yet, its interesting. When you get a long downhill, tap your throttle and the gear display in the speedo changes to D and it coasts (freewheels) until you touch the brake or accelerator. Although mine sometimes doesn't go into coast and sometimes is activates when you take your foot off the accelerator. Must read the book to see if I'm doing it correctly.
Barrington Caldbar
Derbyshire
Looking to buy
Thanks all for your helpful thoughts. Last night I used the manual gears on a steep hill and set it at M4 which gave me a good balance between a low enough gear and braking to feel comfortable so that's the way forward, I think.
RockinNRollin
RockinNRollin
Manchester, UK
T6.1 Ocean 150
The DSG box can only react to the inputs it has; it will shift down gears when it detects excessive load in a given gear or where it detects the brakes being applied consistently but speed isn't reducing by much. It can't however see what is really going on; this is where the manual function is useful. My biggest pet hate of the DSG box is how early it shifts to 2nd gear, so much so it almost drags the clutch a bit as it does so.
Kayleigh
Kayleigh
Back in the Beach
London
T6 Beach 150
If you haven't discovered coasting yet, it’s interesting. When you get a long downhill, tap your throttle and the gear display in the speedo changes to D and it coasts (freewheels) until you touch the brake or accelerator. Although mine sometimes doesn't go into coast and sometimes is activates when you take your foot off the accelerator. Must read the book to see if I'm doing it correctly.
During my month of T6.1 ownership I found the coasting function to be very frustrating compared to the T6. Sometimes it would not coast at all regardless of tapping the accelerator. When it did engage the van seemed to lurch forward slightly.
The whole coasting experience is far better implemented in the T6 in my opinion.
B J G
B J G
Stamford
T6 Ocean 204 4Motion
Since having a DSG remap my T6 changes down to try to hold cruise speed rather than just previous speed build up with incline. Std cruise not ACC so no brake action .
CaliforniaPhil
CaliforniaPhil
Midlands
It's the slight lurch I hate, if I was a passenger I would be asking if there is something wrong with the engine. Fortunately my wife hasn't got a clue about mechanical stuff, so ignores it.
B J G
B J G
Stamford
Only way that I know that it's downshifted is by the gear indication & revs.
Perhaps a remap by TVS might sort it.
Couldn't access their online site for a link?
edocali
edocali
Kingston, UK
I too often use manual mode - or force a downchange with the paddles - but as the van speeds up downhill, the DSG will eventually upshift forcing me to brake - I can't rely on engine braking alone. This is not the case with manual gearboxes in my experience
Viktorgeorge
Viktorgeorge
Starlight Blue Ocean 4Mo MY2023 older bellows
Suffolk
My Ocean has the same inconsistency, sometime coasting sometimes not, but thankfully no lurch.
After a year I am pretty sure the inconsistency is just that: as I have failed to master a consistent response. I am now just used to its quirkiness.
RockinNRollin
RockinNRollin
Manchester, UK
T6.1 Ocean 150
I think a 2 litre 4-pot engine only has so much engine braking potential in a vehicle approaching 3 tonnes!
chockswahay
chockswahay
Scotland
T6.1 Coast 150
Paddles? Paddles! What paddles? Mine doesn’t have any :oops:
andyinluton
andyinluton
Tapping the accelerator (or brake) would turn off coasting, it would assume you want to go faster so would engage drive.
RockinNRollin
RockinNRollin
Manchester, UK
T6.1 Ocean 150
Brake yes, but accelerator often it just goes back to coasting again.
No DSG paddles on mine either but I'm not missing them - had them on my Octavia vRS and even though that was much more of a sporty vehicle than the Cali, I still didn't really use them!
