Your choice. Your DSG box was OK at 50k, and what about at 60k or 70k. But no doubt you sold it on before then.I got sick off dabbing the brake then dabbing the throttle more so when going down hill so i went back to normal function and doing what i use to in my golf estate,drop it into neutral and coast then back in gear much easier after 50000 miles of doing that my dsg was still perfect.
I'm only telling you how it works. It is illegal to disengage the engine from the gear box by putting the gear box in Neutral VW and other manufacturers get round this by using the Clutch pack in a fail safe mode in the Coast function as the Clutch Pack will automatically engage if there is a problem.
One day you could get brake fade and the DSG box fails to select the correct gear in time and there is a sharp L hander in front of you.
