Kitchen strip light above cooker replacement
Britannia1234
Torquay, Devon
T5 SE 174
Hi,
I have just removed the strip light to check the connection, which is fine, but I am having a problem putting it back in, as it is a tight fit. I slide it in from right to left, but it is the right side that I am struggling with. I don’t want to force it, and then have to replace the light. can Anyone offer some useful advice please.
I have fixed it thank you, using brute force
Often the case. People complain about the fragility of some of the fixture and fittings but sometimes they can be a b****r to remove or replace. Well done.
I have exactly same problem will try again
It’s not easy but I just really pushed hard on it, and I clunked back into position. I was in two minds how hard to push on it, but glad it’s sorted now. Good luck
