Leak from clean water tank...
2CV67
2CV67
Alsace
T5 SE 140
Having just filled the clean water tank prior to a trip, I now see water seeping from the rear of the kitchen unit onto the boot floor (the van is parked slightly nose-up).
Obviously bad news & presumably a kitchen-out major job.
Any comments or suggestions?
Thanks!
Yes, i had that too. On mine it was the internal hose connection to
the filler cap, the jubilee clip needed tightening.
When i fill up now i make sure my hose goes in past that joint.
@larrylamb, i would recommend that on that new filler cap that you bought
you fit a pipe on the internal part, about 6" will get it past easy.
Search is your friend....
Check out this :
Could be thesame problem
