Emil Silenhag
- Messages
- 275
- Vehicle
- T5 SE 174
Model year? What kind of car? Probably smaller changes. I can’t see in the pictures, but probably loosen that plastic strip will take you forwardHopefully you can help, I’m following the same process outlined in your post but I’m stuck.
I removed all the parts to get to the pump motor to check the oil level, but I have a block of foam, and don’t see the metal plate you refer to. Also, there is a plastic strip in the way holding the foam block - see the green arrow.
Did you have the same problem ?
