Well unless it is just me, I was informed many years ago that it was not good practice to regularly run fuel tanks at a low volume as this concentrated the various contaminants that are present in the fuel diesel/petrol in particular water, which gains entry through various methods ( atmospheric changes in temperature/humidity and poor handling etc: ) . One of the reasons that there is a fuel filter in the supply line. Also with many modern engines utilising injectors manufactured to very fine tolerances and very high output/pressure fuel pumps, such contaminants can cause serious/expensive damage.There are plenty of legitimate reasons why people might want to keep their fuel tank low, and only top up a little each refill. 70/80 litres is a refill limit not a refill target. For those reasons I think it is a little unkind to refer to people who would routinely refuel to under a quarter of a tank as "numpties". It wasn't until very recently that we learnt of the problems associated with routinely keeping the tank low.
Running on low fuel volumes, with more frequent low volume refuelling can increase the amount/incidence of such contamination due to repeated opening of the fuel tank and low tank volumes concentrating such contaminants thus increasing the risk of damage within the fuel system, especially in modern engines that are engineered to very fine tolerances.
So, in theory, and I personally believe in practice, the fewer times you remove the fuel cap to refuel, the less chance of introducing such contamination.
Do as you wish, accept or don’t accept my reasoning, we are all free to do as we wish.
And I still maintain that someone who runs a modern vehicle with £5 of fuel in the tank and tops up with the bare minimum is a Numpty, or it’s not his vehicle.
