CannonDale
Looks like a good design, as raises the bottom bottom board slightly so should prevent the any slack in the boardbag from flapping on the roof (usually cured by turning the radio up!) Does it slide into the t-tracks on the top of the roofbars, and how do you tension it?
Yes it does slide into the tracks and to tension you just push the black bar inwards to secure the board, there is a key to release the arm and pull it out to remove the board.Looks like a good design, as raises the bottom bottom board slightly so should prevent the any slack in the boardbag from flapping on the roof (usually cured by turning the radio up!) Does it slide into the t-tracks on the top of the roofbars, and how do you tension it?
I was just looking at the lock rack thinking 'what a good idea' when the OH points points out that an iSUP can just be deflated and voila! You can slide it out of the lock - or is there something I can't see?
Are the lockracks still going well? I'm thinking of getting some for my cali but worried about the extra weight when lifting the poptop (have a roofbox too)Anyone looking for a secure carrier for their SUP or kayak have a look at Lockrack, no need for straps or rope and the arms lock the board to the rack. The one I have will hold two SUPs or a kayak.View attachment 47732
