Loss of mains power?
ajdowson
T4 PopTop
Hi,
I was running a heater in the T4 van - on mains hook up, via one of the euro sockets.
It was working fine for a while but all electrics in the van seem to have gone dead. The hook up cable is OK, but now nothing at the sockets. The breaker under the sockets seems fine (was still in up posn - tried cycling up down, no effect. whilst the breaker moves ip down seemingly as it should with clear spring action, the test button didn’t seem to work properly - so might be something to look at there).
Any other thoughts? no sign of any wiring damage. There is no other fuse between the external socket and the breaker I assume (which should flip first if any issue in any case?)
Cheers J
Have you checked the state of the mains hook up cable pins and sockets? We had an incident where some dirt and water got into the socket that plugs into the van. The result was intermittent power and sparking/charing on both parts of the connector.
