rich11235
Done, top tip thanks. VW SMG Cowfold is literally up the road from us so that's servicing sorted with a discount! (maybe they can also fix the reluctant door microswitch if I get fed up...)
I can dig out the drawing for the connections and the BCU is below and to the right of the steering wheel.Loz, many thanks. I will try earthing out the brown/black to see if that brings the light on. Any ideas where the various "coupling stations" are (D-pillar, A-pillar) and how to access them? And also where the BCU / J519 is?
Hi Brian, where is the diode?Boot light stopped working on my van. The diode was the problem. It had gone open circuit. It's a very easy job to solder in a replacement diode. A diode capable of taking 1 amp is okay.
It's at the back of the light fitting beside the bulb.Hi Brian, where is the diode?
