larrylamb
I think it is 5150mm long so only 155mm more than the SWB Cali.The biggest downside I've seen with it so far is the extra length.
An earlier reply indicated 23.6cm longer. I'm out and about so can't do the research, but in terms of it being an everyday alternative to a car, it is quite a crucial factor.I think it is 5150mm long so only 155mm more than the SWB Cali.
Yes , you're correct. From memory I wrongly thought the Cali was 4995cm long.From the respective MB and VW websites:
Marco Polo is 5140mm long
California T6 is 4904mm long
So a difference of 236mm.
Mostly located in the wheelbase plus a bit on the rear overhang. Strangely it has a shorter front axle overhang. Looking at a photo I'd have thought the MP was a long nosed vehicle. Not sure how the Driver's head position compares between the Cali and the MP, to the front bumper that is.An earlier reply indicated 23.6cm longer. I'm out and about so can't do the research, but in terms of it being an everyday alternative to a car, it is quite a crucial factor.
Size matters when it comes to campers that you want as a go anywhere vehicle. A LWB Cali based conversion I dismissed when I was in buying mode at it removed a car parking space from my drive for starters.
Can anyone advise the height of the MP?
Ah! Thank you. I had looked and looked at the MP Brochure but I think my thoughts were elsewhere and couldn't see it
At least it is under the 2m.
Not much point having an extra 9" if the boot is full of chairs and table. The stowage of those items is what sets apart the Cali from other VW conversions and the MP. I wonder why they didn't copy the Cali in those respects.So MP is 9 1/4" longer than a Cali.
Just 2" shorter than my LWB T4 at 5189mm
I reckon that has you overhanging many a supermarket car parking space.
1,980 I think, very faint print in online brochure.Size matters when it comes to campers that you want as a go anywhere vehicle. A LWB Cali based conversion I dismissed when I was in buying mode at it removed a car parking space from my drive for starters.
