homerorchid
- Messages
- 229
(2019 Ocean - 2 floor rails - 4Motion) The lever used to slide the rear bench seat forward/back doesn't spring back to its position against the seat. The lever functions OK when I need to slide the seat forward/back, it's just that its floppy and rattles when driving. I've tried this suggestion from a previous thread without success "pull the seat back a bit without using the lever, grab the underneath of the seat it should spring back" (didn't work for me). Also tried slightly twisting the seat when moving it back to see if might be out of alignment (no joy), made sure there is nothing behind/at the side of the seat to restrict movement. Any ideas would be appreciated, thank you
