Painted Pilgrim
The 2 in the b pillar were fitted first, 1 for the TV and 1 for the stereo to run on leisure (i think)If the Fridge is drawing power when Off then it will be a first, I'm afraid.
You said there were 3 aftermarket switches. What does the 3rd do?
Even if the 50/75amp cube fuse has gone it wouldn't produce a 0.8amp current draw.
The 3rd switch in the dash was fitted 3 years ago when a new stereo was fitted as I've spoke to the company that fitted it. They piggybacked off the number 11 leisure battery fuse and this is the switch for that. If the B pillar switch is not on though the stereo will not work at all regardless of this dash switch position.
There is no extra current draw when the switch is on until you turn the actual stereo on.
Any ideas? I think the next step will be the auto electricians...
