D
dieseldesmond
Had total shutdown of the camper section of 2020 california coast details no fridge, no heat, no lights, no water pump, tried to find fault using the latest vcds software but to no avail. I think vw have control of this part of the software by way of a firewall so I had a go myself, no1 checked all fuses under the bonnet with my multimeter all good, no2 checked all under dash near steering column right hand drive all good, no 3 removed passenger seat to check all fuses no luck all good, next I noticed a black heavy-duty single contact relay or isolator with heavy-duty red battery feed going into to the unit it was live, but the same heavy cable coming out of the relay to supply the camper section of the california was dead , problem solved, Please note all the electrics for the camper section on this california came from one 12 volt leisure battery under the passenger seat, hope this might help someone. A LITTLE KNOWLEDGE IS DANGEROUS BE CAREFUL
