I
Ianvonlux2023
And drill the plates so they are level !it’s so funny. They had 1 job.
And messed it up.
Hope you checked for scratch marks before you took handover.
There are pre drilled holes with screwed inserts behind.
So you’ll have to drill a hole (in the number plate) further down on the right. Then lift that side of the number plate up.
Exactly what my first job is tomorrow.Don’t drill any holes. Take those off and throw them in the bin. Get some nice plates and put them on with 3M double sided tape.
Pretty sure that’s what drilling a hole lower on the right hand side (existing hole) of the number plate would achieve.And drill the plates so they are level !
I thought a big UK sticker was obligatory to meet EU regs.Exactly what my first job is tomorrow.
Don’t want JCB group on my plates thanks.
Can’t decide to go UK on plate or a separate sticker
Im just back from three weeks in Europe. Consensus seems to be country code on number plate or a big sticker. Rarely both. Often neither!I thought a big UK sticker was obligatory to meet EU regs.
Uk on plate ok for France , but big UK sticker needed for SpainIm just back from three weeks in Europe. Consensus seems to be country code on number plate or a big sticker. Rarely both. Often neither!
It’s about £8 for a new plate off Amazon, next day delivery. Just put a new set on mine. I would just do that and drill the holes in the right place this time. Despite your dealers efforts, it’s really easy. As others have said, the lugs are already set in the body work at the back so use the same screws and as long as VW have set the lugs in the right place (no guarantee!) all will be fine. I wouldn’t use double sided pads personnally, prefer to do a proper job.Hi, How are the number plates attached? Does the garage drill through the plate and the metal body work or are there "lugs" on the bodywork from factory? I want to move my plates as they are not straight but I'm reluctant to drill holes in the body work!
Over 3yrs on it pains me to buy new plates as theres otherwise nothing wrong with them, apart from garage logo. Maybe some 3m tape and cover the garage logo.Pretty sure that’s what drilling a hole lower on the right hand side (existing hole) of the number plate would achieve.
But I agree with @dspuk
Throw them and get new plates.
Keep the plates, Use the double sided, but retain one screw fixing. Stick the ‘other’ screw cap on with some superglue to cover the hole.Don’t drill any holes. Take those off and throw them in the bin. Get some nice plates and put them on with 3M double sided tape.
, & Cyprus and Malta.Uk on plate ok for France , but big UK sticker needed for Spain
Did the £8 plates have writing on the bottom of the plate like a BS number ?It’s about £8 for a new plate off Amazon, next day delivery. Just put a new set on mine. I would just do that and drill the holes in the right place this time. Despite your dealers efforts, it’s really easy. As others have said, the lugs are already set in the body work at the back so use the same screws and as long as VW have set the lugs in the right place (no guarantee!) all will be fine. I wouldn’t use double sided pads personnally, prefer to do a proper job.
Given the number of illegal plates on the road with the letters WA NK ER moved closer with Bolts used to change some letters and numbers and the total lack of police giving two hoots I doubt not having the right letters on will cause many issues outside of MOT.
Don’t get me started on t***s like that!Given the number of illegal plates on the road with the letters WA NK ER moved closer with Bolts used to change some letters and numbers and the total lack of police giving two hoots I doubt not having the right letters on will cause many issues outside of MOT.
When I got mine they asked if they were “show plates” and if I wanted the letters leaving off. I did not.
You mean TW 4 TSDon’t get me started on t***s like that!
This option utilises the VW screw points.Hi, How are the number plates attached? Does the garage drill through the plate and the metal body work or are there "lugs" on the bodywork from factory? I want to move my plates as they are not straight but I'm reluctant to drill holes in the body work!
Would number plates clip in, or is it then necessary to use double sided adhesive tape/pads?This option utilises the VW screw points.
NEW GENUINE PAIR VW NUMBER PLATE HOLDERS 520x110mm STANDARD UK SIZE 000071801BC | eBay
These are supplied in boxes of 20 and i split them into pairs. The forth from last photo is the part label on the box stating "Distributed by Volkswagen" just to be clear. VW EMBLEM NUMBER PLATE HOLDERS.www.ebay.co.uk
