D
dominichayhoe
So, I'm still pondering over what to do to have an off-grid system with working 3 pin sockets.
Be interesting to hear everyone's thoughts.
As I see it there's only really two options without going crazy, mostly because of the location of the leisure battery.
Note: I have the solar panel and victron mppt which will charge either/both systems.
1. Replace the current leisure battery with a low temperature lithium battery (which I can get 110ah for the same size as the existing battery), run the cables to the electric cupboards from it and install an inverter, B2B and mains/battery switching station (to automatically choose the correct power source, mains or leisure battery through the inverter).
OR
2. Purchase a battery back up such as a Jackery, and mains/battery switching station.
Pros/Cons
First system is more complete but limits the size of the leisure battery, means you'll probably need a low temperature lifepo4 battery and you have to run a high power cable to the electrics unit from the bonnet and you will require a B2B too.
Second system means you can use the Jackery outside the van, don't have to worry so much about the cold, and don't need the B2B, but either have to run cables in any case to charge from the alternator, or more likely move the unit when/if this is necessary. The cost of a 100w Jackery unit is similar to a lithium battery with inverter in any case. Doing this takes up space in the electrics cupboard obviously. You can't upgrade the inverter if you find it's not man enough.
Plus the fact your electrics system won't use the leisure battery at all if this unit is switched on, so you'll have to remember that if you want to use it for lights etc and only switch the Jackery on maybe if you need the 3 pin plugs. Then maybe you'd do that anyway with system 1 otherwise you're inverting your electrics to 230v to invert back to 12v for the lights etc. So I may be wondering about things that are superfluous here!
I'm sure I've missed lots, so feel free to add your comments.
I should add, I have built these systems before. My previous camper has a Lifepo4 leisure battery with inverter but no switching station and is under the drivers seat and has worked well for over a year.
OR
Pros/Cons
