Oil Filler Cap (Mines called Basil)
glen
glen
Morpeth, Northumberland, UK
T6 Ocean 204 4Motion
Hi All, Please don't tell me I'am the first to drop the oil filler cap into the engine. Have a look under van nothing gets down on the bottom to have a proper look, Yes big cover on the underside had to undo four bolts and was able to see inside There it is sitting there like Basil in the biscuit tin managed to fish it out and give it a right bollocking. Please don't make the same mistake Put it on the floor don't rest it on the engine :oops:
Noted! :thanks
But you’re having to add oil already?
How many miles have you done, and filling oil already??!! :eek:
There's a similar tip with the portapotti - never, NEVER, put the lid on the side of the emptying trough. Just don't do it. You won't want to put your hand down THAT hole to try and retrieve it!!! Always put it on the ground :)
It says oil filler CAP, not oil filler CAT! :D
Hi Just took oil cap off to have a look in side its a Man thing.
I get it. Just don't forget to clean all the grit and dirt from the cap once recovered.
