SlidePods
Guest User
I am away on holiday at the moment so if you want to know if we can supply you with one you wil have to email Tracey on [email protected]
Either that or buy a cheaper one that will destroy your leisure battery, your choice.
yep they recharge when on the move and rear sockets are fed by alternator giving 14,8v
when on hookup the voltage goes up as well but in cycles with voltage fluctuating.
Most fridges have battery protection but keep in mind the low (12v)voltage drops fast over long cables. So fridge might shut down way earlier than battery is low.
There are at Least 3 x 12v sockets in the rear that run off the Leisure Battery, 1 to the rear of the front passenger seat, 1 near the sliding door/bench seat and one in the boot. These run from the Leisure Battery which will be continuously recharged if the engine is running or if on the Campsite Mains.That’s almost too technical for me lol
So basically, on the move the fridge will power off the leisure battery which is recharging at the same time...but when I park up, it will continue to stay on so long as I’m plugged in, and for a couple of days if off-grid?
Not quite sure how I overcome the issue with long cables that you mentioned?
Not a helpful statement - dual mode fridges/coolboxes do not destroy your leisure battery. If you check the specs they use about as much power as the more expensive ones. They will run down the leisure battery more quickly as they are on all the time and the more expensive ones cycle on/off as needed to keep the temperature at the right level.Either that or buy a cheaper one that will destroy your leisure battery, your choice.
Actually that's not quite correct either. If the weather is hot then the dual mode coolboxes don't work harder, they just don't cool to such a low temperature. They are normally rated as cooling to 20C below ambient. Interestingly if the weather is hot the more expensive fridges have to work harder, so they will be on more often and drain the batteries more quickly.If too hot can drain battery faster.
We can confirm this. In fact for even longer if you have a solar panel.yes should be fine for couple days
The cable from Fridge to 12v socket should be as short as possible to minimise voltage drop off. This will only be a problem if wild camping WITHOUT plugging into a Mains supply.
A long cable from the 12v socket to Fridge can result in a voltage drop along the wire. The Fridge will stop working if it detects a voltage of 11.5v. The Normal 12v supply starts at 12.7v and drops over time if you don't have the engine running or not connected to 240v mains. With a long fridge lead the voltage drop might give a voltage of 12.3v at the fridge so when this drops to 11.5 the fridge stops, but the actual voltage at the Leisure Battery is 11.9v, so the fridge stops sooner than it needs to.
Obviously, you don't have this problem on an Ocean - no voltage drop.
'proper' fridges are 5 to 10 times more expensive than dual voltage coolboxes. What do the coolboxes waste in the long run?There are proper fridges with compressors and coolboxes with Peltier element which are a waste in the long run.
Some owners use thicker cable and wire directly to the Leisure Battery. I'm sure someone will pop up with more advice of exactly what to use and how to do it.Thank you sir - this is very helpful. I can't see us wild camping often but if we did, what sort of cable are we talking about to avoid the voltage drop-off? Do these cables have the 12v cigarette lighter type ends? Am I correct in saying that the cable can be as long as I like if I'm plugged in on a site?
If the fridge turns out to be a bit noisy at night, I'd probably look to keep it in a drive away awning to be honest.
Thanks again!
Martin
Fridges come in two types.
A - Compressor
B - Thermo-electric
Type A is significantly more expensive, but uses significantly less power. Type B is significantly cheaper, but uses significantly more power. As power is limited, type A is the one I would recommend.
It draws its power in one of three ways from the leisure battery.
1. Direct from the leisure battery
2. From the leisure battery which is being recharged from the engine
3. From the leisure battery which is being recharged from mains electricity
#1 can work at any time
#2 will only work when the engine is running
#3 will only work when the van is hooked up to mains electricity
Okay, thanks for the reply - I don’t fully understand but I’m sure I’ll speak to the suppliers before I buy one etc.
