D
DVDF
- Messages
- 2
Hello!
I have the original VW T5 Bike rack that i really like, since it is bomb proof.
The only problem I have is fitting my carbon fibre bikes on there.
One problem is that the mtb frame is very thick so the arm barely grabs it, and i am not very confident if it will hold the bike enough.
Second problem is that you are not allowed to tighten the clamp to much since it can damage the carbon frame.
So the best solution would be if i could fit the arm from Fiamma or something similar (see attachment) , sine the plastic strap can hold almost any bike frame + you can over tighten to damage the frame. Problem is the original VW bike rack is oval shaped, every other manufacturer with arms that i would need has round and thinner rack so it won't fit.
Did someone had similar problem and found the solution?
Thank You!!
David
Thank You!!
David
