problemas conexion electrica
maurizio
maurizio
menorca
Grand California 680
Hola,
al usar la calefacción de gasoil modo mixto se bloquea la conexión electrica y tarda horas antes de volver a ser efectiva, es normal? alquien tiene una explicación, muchas gracias, saludos
maurizio
maurizio
menorca
hola algor
queria decir que se interrumpe la conexion electrica
Breeze1
Breeze1
Dorset
Grand California 600
Hola,
Maurizios translation,
Hello,
When using the mixed mode diesel heating the electrical connection is blocked and it takes hours before it becomes effective again, is it normal? someone has an explanation, thank you very much, greetings
maurizio
maurizio
menorca
Hi,
the problem has been because my external electrical cable is 1.5mm2 and it is not enough
a minimum of 2.5mm2 is needed
